Transom assembly is it savable or junk?
#31
https://claussmarine.com/products/me...hoCsx8QAvD_BwE
I went this route, I bought a new Mercruiser HP transom assembly I'm picking it up Friday. Should make my life a bit easier!
#32
my new setup will be in the area of 550hp so im sure its not a threat to this assembly. Big nut to swallow but will give me a good piece of mind and make life a lot easier on reassembly.
Question, the engine coupler do I need to worry about that now? Their not cheap either and mine looks fine but how do you really know? Looks like its either good or it fails, the rubber is not cracked or dry rotted.
#33
#34
Congrats on the transom assembly
#37
ohhhhh PRETTY!!!!
#39
I agree, I was getting milky oil in the drive pump reservoir so the lift cylinders were leaking, the steering pin was leaking and turned out to be a total mess, and the backing plate was cracked. It was time! Im just thankful the transom isn't a total wreck.
