Valves
Old 02-28-2023, 08:05 PM
Default Valves
Getting ready to put a set of aluminum heads together. I've always believed in using a Heavy Duty intake and Severe Duty exhaust for marine use. But is it really necessary in a naturally aspirated application? Would a standard race valve be sufficient. End goal is 600hp BBC.
Opinions please.
Smitty275 is offline
Old 03-01-2023, 12:26 AM
Received 1,993 Likes on 995 Posts
IMO, YES.
Inconel exhaust valves, when do you need them?
Griff is offline
Old 03-02-2023, 08:44 PM
DRAG's Avatar
Good valves aren’t that expensive and cheap valves aren’t that cheap. Go for some good stuff and don’t skip the inconel exhaust.
Formula 353
Merc Racing 540s
DRAG is offline
Old 03-03-2023, 03:31 AM
Not the place to save a few bucks in a marine engine build.
DrFeelgood is offline
Old 03-03-2023, 04:49 PM
I'm right there with all of you. Just wondering if technology had gotten good enough of the race series of valves. Did get a rare chance to talk to an old acquaintance that builds offshore power for a living in Virginia. He said they use Manley Severe Duty in everything naturally aspirated. If it's got a blower they go to inconel for the exhaust.
articfriends (03-04-2023)
Old 03-04-2023, 11:56 AM
articfriends's Avatar
Its always been a question. I have personally never had a valve failure BUT I use better inconel exh valves in everything. Im currently building a pair of 502 mpis with factory heads, same question, the factory uses Eaton Inconel exhaust valves BUT they are 2 piece , a hp500 and 500 efi with same heads uses manley inconel exh valves, more spring pressure, more rpms, more lift. Could I have reused the eatons, probably BUT I never have reused them with more spring, lift, rpms as a failure will make me go far backwards on a build when custpomers mad AF at me ! so as much as Id like to, would cost $$$ big if a head comes off. Smitty
articfriends is offline
larose481 (03-06-2023)
