Wanted bad MFI 1 computer
https://www.ebay.com/itm/293507146262
12129008, 12186041, 12186043
delphi/ naptiv 32way
gonna be one of those 3, there about 11$ at mouser
MEFI 1 thru 4 use the same 32 pin connector, there just keyed different using a indexing cover
I don’t know what one of the three part numbers I need so I was thinking about buying all three part numbers so I could pay shipping one time. If I buy the wrong one can I modify it so it will plug into the factory harness? From the look of it I need 2 plugs now I’m really unsure of what parts to order.
thanks for the help
thanks for the help
articfriends (11-30-2023)
Part number difference is the color
12129008 Male BLUE 32 pin
12186041 Male BLACK 32 pin
12186043 Male GRAY 32 pin
These appear to me to be PCB solder type, so if you want to use wires then, like 12129025 but then you also need to get other items like the pins, back shell. I would need to do more research to determine exact what would be needed. This is the connector and look at the notes
https://www.customconnectorkits.com/12129022/
