300X Help?
Just had an issue with my starboard motor and thought someone on here may be able to help me diagnose the issue.
Was running fine with both engines around 5800 rpm. starboard started losing rpm slowly, so I shut it down.
When I try to restart it turns over fine, ( no knocking ect.. )
Will not start without me applying a lot of throttle (as if flooded.)
Will only stay running at around 2K rpm for a while, then dies.
Lots of raw fuel and oil coming out of the lower exhaust port.
I removed all the plugs and there are no obvious fowled plugs.
Motor turns over freely with what feels like good pressure from each plug hole.
Was some raw fuel also in the bottom of the air plenum.
