LS style throttle bodys
has anyone tried running dual LS style throttle bodies on top of a root blower? they seem to flow as much if not more then a 4150 style throttle body.
are you talking about a bug catcher?
like this?
https://www.ebay.ca/itm/154485586657
im meaning like running a adaptors to go from a 4150 carb or 4 barrel throttle body to a GM 4 bolt 105MM motor blade
like this?
articfriends (05-11-2024)
I have some brand new billet 4500 throttlebodies.,was gonna use them on my side mount whipple set up.then I sold the motors.have some killer double swap gen 6 cams too
I know what you are saying, and I haven't seen it.
This is the closest thing to a production piece that exists to my knowledge.
https://www.alkydigger.net/product/EN1014-B1.html
articfriends (05-14-2024)
Only issue I could see is having to add fuel rails above the blower as well since we are talking roots blowers....they need fuel running through them...I strongly considered this on mine as holley makes an add on fuel rail that mounts to a 4150 flange but it was far more cost effective to just run terminator "throttle bodies"
ive got TBS efi plate so the blower will be wet
i was looking at going over to the terminator system, after talking to holley it was cheaper to keep the HP system, get a plate and the adaptors. i wish the terminator was plug n play. would have been way easier:P
