Full Hydraulic Steering System Operation
I only have a power steering pump on my Stbd engine. I want to create some redundancy in the system if I lose the Stbd engine.
How much steering is there with no pump pressure?
I'm toying with the concept of an electric power steering pump as a backup. Obviously not as a full performance option, more of a limp home mode running only 1 engine.
Setup would be a manual valved isolation until required. No need for a single reservoir.
Obviously pressures would be lower. But limp mode that should be gtg?
You will have steering, it will feel like a H Farmal pullin a 2 bottom plow..............putting it in a slip on one is a pita
Tartilla (05-08-2024)
I don't typical use slips...more a mooring. But even getting on to a launch dock could be a pita.
How does the steering wheel control system work? Is there check valves that keep the steering cylinders locked in place until pressured and relieved?
Looks like there's a lot of EPS...electric power steering options from many vehicles. Volvos being one of the primary donors to perf street cars etc.
Seems like a viable option. Easy mount, and easy plumb. Also makes easy bleeding of the system without running the engines.
JaniH (05-09-2024)
Unless you have removed the steering lines try it. The pump in the hydraulic helm is small so it's gonna take a whole lotta turns to maneuver the boat. Even more due to the fact that the steering rams are in parallel, you may want to change that to series but I didn't want too much sensitivity at speed, and had to turn quite a few turns for lock to lock.
