Why are the trim tab hydraulic tubes so short on these K planes
Since most transoms are 3" thick, why are the hydraulic tubes for the tabs 2 3/4 when they are installed all the way? The outside of the double ended hollow stud has the plastic nut on it I can only assume for sealing. If I take the nut off and put the stud flush with the outer edge of the tab, then there is more than enough lenght inside to go thru a 3" transom and still put a washer and nut on the inside. If the stud is bottomed out like I found, then the transom has to have a recess cut into it. . Or could it be that I just have a pair of the wrong tubes? Another pair of K planes use the same length tube, so I dont think thats it.
![](https://cimg3.ibsrv.net/gimg/www.offshoreonly.com-vbulletin/2000x1504/img_2166_6b8f4487cfcc591222e5847b8ebaedda5cc19630.jpg)
![](https://cimg7.ibsrv.net/gimg/www.offshoreonly.com-vbulletin/2000x1504/img_2168_00a77fc702103bd7cd607b04ed661b1a2f7a0f1b.jpg)
![](https://cimg4.ibsrv.net/gimg/www.offshoreonly.com-vbulletin/2000x1504/img_2167_a1e3609ba426a0a29308719ada04b48213885b2b.jpg)
Were doomed!
actually most outdrive transoms are between 2" to 2-1/4"
if you have a 3" thick transom then maybe you have outboards?
either way i know there are longer tubes for the k-planes you can buy....i had to replace a set and found different sizes...call BAM im sure he can set you up or tell you the size of the threads to get some longer ones.
-Wally
-Wally
Well Wally I measured and your right. My transom is 2 1/4 thick. I may have been thinking of the transom on my 38' Scarab that was 3" think
Offshoreonly Advertiser
Stud kits at the bottom here, Mercury is sure proud of them!
https://www.mercruiserparts.com/bam/...32085/8504/375
Marc
www.go-fast.com
www.bammarine.com
www.cyborgtransmissions.com
It's not alive -www.BoatStuffExpress.com - temporarily retired
Marc
www.go-fast.com
www.bammarine.com
Were doomed!
![EEK!](/forums/images/smilies/eek.gif)
I dont remember paying that much for them when i had to replace a set on some K-planes i redid....thats crazy! Almost makes ya want to go to a local machine shop and see how much for them to make a pair!
-Wally
-Wally
As a small machine shop owner, I can tell you they'd be about $525. Sound fair?
Thanks. Brad.
Were doomed!
-Wally
-Wally
Wally,
Whoops.... I misread (or short term memory glitched) the price on the listing. I swear I know how this capitalism thing works....
$525. And that's my final offer.
To be fair, Merc's kids gotta eat, too....![Roll Eyes (Sarcastic)](/forums/images/smilies/rolleyes.gif)
Thanks. Brad.
Thanks. Brad.
Wally (Today)
