Bravo One stuck in up position
I'm working on a 2005 Donzi 22 (496 HO Bravo One) that's been sitting in a garage for 8 years with 214 hours. When I hit the trim switch I can hear the trim pump, but no movement on the outdrive. Could somebody steer me in the right direction as what to look for. Thank you!
Assuming there is fluid in the reservoir?
You can crack a line loose on a trim ram and run the pump. If fluid sprays out there is a problem with the trim cylinders. Will it move if you help it? Like say with someone standing on it? Bravo trim cylinder caps are known to corrode in the seal area and can freeze it up. I had to rebuild mine last spring. Rebuild kits are like $15 a piece. A lot of people just buy the cylinders rebuilt and replace them.
Not sure if this link will work. But heres what a bad one looks like.
Replacing Or Rebuilding My Mercruiser Bravo 3 Trim Cylinders - Start To Finnish | ShrimpNFishFlorida? is Florida's Official Anglers Social Networking Community?
NEVER store a boat with the drive cranked to the moon........
Yep- better replace the Bellows now also.
