496 mag 375 hp no fuel into engine ?
Hi everyone I not sure where to go for here but I've check as much as I can with a meter and looking at connections. still no fuel into engine I've sprayed starter fluid and it wants to start but no way . I have 46-48 psi start up fuel pressure and then drops to about 38 psi while trying to start . all fuses have been check any ideas where to go from here ? I'm going to get the disk from rinda for the computer to check for codes and other things I guess . what would I check along the line for fuel injectors not firing. thanks Dan my number is 754-422-8805 any ideas or I'll check back here thanks again.
