Color of the Drive lube after 35 Hrs ??
No chalking at all , i will exchange the coupler this winter because i want to go Silent choice and i have the remove the motor for install the y pipe , i remove the top cap and every thing look good . but i can not turn the output shaft , this is why i think is the bearing seized , i will keep you posted because the mechanical is supposed to work on the drive this morning, i still look for not to bad news $$$$
I would suggest using the Severe Gear in the Bravos. Either the 75w-90 http://www.amsoil.com/storefront/svg.aspx?zo=1132530 or the 75w-110 that Teague now recommends http://www.amsoil.com/storefront/svt.aspx?zo=1132530 .
