Will Merc 3A or 5 fit on TRS Gimble?
have a customer who blew up a trs and wants a better drive, he wants 3a or 5, not sure if it fits on the trs gimble and if the x dimension is the same even if it will fit or needs to be raised, thanks
The answer to your question about the interchangeability of the #3A-#5 SSM drives to a TRS gimble, the answer is no. You would need the #3-#5 gimble assm. and also, I believe, the appropriate tailstock for your transmission for #3-#5 drives. I'm almost sure that the TRS transmission tailstock, for a plug-in transmission, is different than one for the SSM drives.
Hope this helps.
Hope this helps.
Lakeside Restorations.com
![](https://www.offshoreonly.com/forums/images/icons/commercial_member_star.gif)
Yes, The Konrads should be something to look into. We sell them if you would be interested.
As far as what can go with a Trs, If my memory is correct the 2a lowers can bolt onto a Trs upper if thats what your guy popped.
Jamie / Lakeside
Jamie / Lakeside
www.LakesideRestorations.com 570-639-2628
We Make Fast Toys Faster, Cool Toys Cooler and Old Toys New!.. Performance, Custom & OEM Parts & much MORE![/CENTER]
Answer is for sure no....I went thru it ...from trs to #3's. Need to change tail stocks, z-dim, and gimbles for sure.
call me if you have any specific questions that you need
954-234-9020
954-234-9020
No it will not. You should look at the Konrad conversion. It
will up grade far better than a III or IIIA. You need to check
the application we just did. Go to Drives and Lower Units. Any
questions call us. 954 237 0332
jeff1000man
02-27-2007 09:45 AM
