gimble bearing
I have heard there is a difference in the gimble bearing between a xr and a regular bravo 1 . if this is so can I install the bearing for the xr in anticipation of a upgrade ? Or is there a difference in the inside diameter , where the driveshaft would be installed into ?
what i would like to know though is ,can I still run the bravo 1 for the rest of the year with the xr style bearing or is the id .or something else different that wouldn't allow it ?
Lakeside Restorations.com
![](https://www.offshoreonly.com/forums/images/icons/commercial_member_star.gif)
If my memory serves me correctly, I believe that the Xr bearing has added clearance for the bigger U joints. The shaft diameter I believe is the same if memory serves me correctly. Also I think the real late model bravo transom assemblies have the bearing that will work on all of the bravos, however I dont recall what year that started for sure..
hope it helps.. Jamie / Lakeside
![Smilie](/forums/images/smilies/smile.gif)
www.LakesideRestorations.com 570-639-2628
We Make Fast Toys Faster, Cool Toys Cooler and Old Toys New!.. Performance, Custom & OEM Parts & much MORE![/CENTER]
