Convert or replace? >
Convert or replace?
Convert or replace?
Old 08-16-2007, 06:46 AM
21 and 42 footers
t500hps's Avatar
Originally Posted by articfriends
Max Machine worx uses std bravo cases and installs their steel towers,its STRONGER then a stock xr tower,the case is identical other wise,too bad your buddy didn't take his a step further,Smitty
I'll ask.....I thought he had a tower put in them but not sure. (and it could have been someone elses towers???)
t500hps is offline
Old 08-16-2007, 11:27 AM
Unless you have steel towlers don't even think about it.
John the Drive Man is offline
Old 08-16-2007, 09:18 PM
Thanks for the input guys. Do the satndard bravo xr's have the steel tower built into the case or is that a bennefit of an aftermarket upgraded drive?
cstobe is offline
Old 08-17-2007, 01:01 AM
articfriends's Avatar
A std bravo xr has mercs version of a steel tower, but it is more of a short,stubby steel insert. It is definately a step above a std bravo's aluminum one that either shears off or becomes deformed once you get the rest of the parts to hold together. On the other hand the best steel tower which is built by max machine worx extends thru the whole upper and uses the benefit of its length (about 12") for its rigidity. They are proud of it though and charge a small fortune to install one,Smitty
articfriends is offline
Old 08-17-2007, 09:35 AM
Charter Member #601
Mr Gadgets's Avatar
cstobe,
All the Merc XR drives have a steel tower in the case as standard equipment. I have not seen one fail as of yet. I have seen a gear welded to the tower but the tower did not fail, just got very hot when the gear bearing failed..
My steel towers have 2" of thread on them, better than the XR Merc tower, but not as good as Max Works. Although I have not had any failures with my towers, and I dont charge an arm and/or a leg to do it.
Smitty, isnt there a change to the bottom of the case that was a problem when you tried to put a spacer in between the upper and lower with the Max works tower?
D*ck
Mr Gadgets is offline
4bus
7
07-05-2007 01:11 PM
dkap1210
12-20-2006 09:32 AM
duksrule
4
07-24-2006 08:09 PM
97BossHammer
02-14-2003 10:37 PM
Quick Reply: Convert or replace?
