speed master to trs
Which Speedmaster will bolt up to a TRS gimbal? Are speedmaster drives more durable than trs? And which props work on speedmasters?
Thanks for the input...
The Speedmaster II is the only SSM drive that bolts to a TRS transom assembly.
They are about 2" longer than the TRS so your propshaft height will be too deep.
The TRS was actually more durable and pasts for the Speedy 2 are pretty much extinct.
The Konrad is a direct bolt-on unit. I've been running the same set for the past 4 seasons (360 hrs)
![Thumbs up](/forums/images/icons/icon14.gif)
if you have the trs the only way to go is the KONRAD there 2'' shorter than the trs which should help picking up some speed and handling from what I have seen and they look kick azz
I have been in a 38ft blown sc boat with those drives and it screamed no worries about the TQ blowing the drive apart like a trs which is rated for 500hp. I think from what I read the konrad is rated for 800hp or more, MGD PUT ONE ON A SUPER BOAT Y2K WITH A MGD 960HP ITS RUNNING CLOSE TO 100. THEY LIKE IT SO MUCH THEY GOING TO PUT A PACKAGE DEAL TOGETHER AND SELL THE Y2K THERE MOTOR AND THE KONRAD. So they must be a good drive. art
