TRS Tips & Tricks
#41
Geronimo36
![Cool Smiley 011](/forums/images/smilies/cool-smiley-011.gif)
I often wish I got a TRS boat cheap and put some Konrads on!
![Angry Smiley 038](/forums/images/smilies/angry-smiley-038.gif)
However, I don't agree that the Konrad is the answer for a bravo. TRS to Konrad is the way to go, it's what it's designed for!
#42
White Knuckles: Trannies are Borg Warners C-72s/Velvet Drive
Flashhat: Gimbals can only be pulled by removing the motors and removing the 8 nuts from the inner gimbal plates.
You need a stud remover to pull the old studs and start making calls to Bam Marine, Speedmasters Inc, Doller Marine, or Offshore Perfomance Specialties for a set of new studs if needed. All 4 of these shops stock plenty of TRS parts.
When I did my external steering I needed extra long studs to mount the Marine Machine wing plates on the drives and they charged $25 each.
Konrads are defintely the way to go if you can afford to pay $10,000 per drive. If you can afford $20K then have both drives gone through and resealed. They really are bullet proof if you maintain them by proper throttling and fluid changes.
#43
All eight fasteners are accessable, the two nuts located under the transmission ears (BW only) are the only ones that can be a bit of a chore but not too bad with the right tools.
I've found that a Snap On semi-deep 3/4 socket and a wobble drive extension works to start removing, after several full turns, switch to a 3/4 flex-socket and you're there.
Been involved in many TRS/Konrad conversions, most twin engine boats can be completed within a days work.
If anyone is interested, shoot me your address in a PM and I'll send you out the installation manual. This procedure is well documented.
Kurt
Kurt
#44
Geronimo36
In the past I've removed the gimbal rings but never the whole assembly with the engine in the boat.
#46
Kurt
#47
There's certainly a lot of interest for a SSMVI replacement but I don't see it happening too soon.
Our SSMIII/IIIA conversion is fully competed and works perfectly along with a few more mph to boot! Just got home from Miami testing the first conversion. More to come on this !!!!
Kurt
#48
I would assume that if you had a merctrans set up you would have to pull the engine...I know that I have not been successful at even tightening all 8 nuts let alone removeing them.
#49
I would go ahead and pull the motors regardless of if you can do it with them in or not. They come out so easily and it makes everything else so excessable. With them out you can replace damaged or old hoses pumps etc.
#50
Registered User
Kurt
Kurt
