Bravo One vs. XR top-cap
Anyone know if the Bravo One and XR top-caps are located in the exact same locations when the drives are installed? Wondering if my dual ram hydraulic steering would have to be re-located if I uograded to the XR drive from the Bravo One. Thanks.
21 and 42 footers
Just changed the flat top caps on my XR's to the "finned" XR top caps. Depends on the type of steering you have. I had to make some spacers for the Latham steering. If you have MM brackets that wrap around the drive but do not go over the top then I believe they will bolt right onto the drive without issue.
