Imco 2" shorty on a 25 Outlaw
the Flightmaster
Nope, havenīt tried one yet. No-oneīs got one here, but maybe I should look for one. 28" should do it. They are one or two pitches higher than the equivilent Bravo, from what Iīve read. i need a bow lifting prop.
I have the 1" spacer fitted, so Iīm waiting for a warm day to give it another run.
hi wild card ive been told not to polish the lower drive less resistance apparently sure looks good thow, i have posted my set up under the baja forum similar setup only i am supercharged im also looking for suggestion's i dont know how to cut and past on here so you'll have to go to other forum good luck nice combo.
the Flightmaster
The guys at Imco said to me also that I should take the unpolished one for the same reason.........but that polished one just looked so sexy! Anyway, I figured that there is gonna be soooo little of it in the water that it canīt make the difference.
What makes more difference is the low water pickup on the Imco.Dual water pickup (Bravoīs) are faster. Iīm told it is because the upper pickup acts like a pressure regulator. However, it only works when there is enough of it still in the water, otherwise the pump will be sucking air. I have closed up the upper four holes (per side) and it works really good.
A 28" Hydromotive would be worth a try, then?
