B-1 Carrier Seal R&R
1 Post
I removed my drives for service over the weekend to discover drive oil inside the bellows. I began to add oil which eventually started to flow from the carrier assy. Noticed on Bam's site there is several o-rings and seals that will be replaced. Is there any bearing pre-load any anything I should know when doing this? Also where can I purchase the ring nut tool?
Pro Marine has the parts and tools. http://www.promarineusa.com or BAM
You will also need a needle type inch/lb wrench to set the bearing preload. It may be cheaper to have it done if you have to buy the tools.
Its most likely the yoke seal and it is possible the yoke is grooved. It may need replacement too.
1 Post
Thanks Jim. I originally thought of taking it somewhere to get done. My train of thought is I'll have the tools to do the other side when its time. Just curious on the extent of damage with lack of lubrication to the bearings and upper gears.
Geronimo36
![Drink](/forums/images/smilies/drink.gif)
Lots of things I threw away the inch/lb wrench...
How bout you?
Geronimo36
Offshoreonly Advertiser
What drive do you have?
Marc
www.mercruiserparts.com
www.go-fast.com
www.bammarine.com
www.cyborgtransmissions.com
It's not alive -www.BoatStuffExpress.com - temporarily retired
Marc
www.go-fast.com
www.bammarine.com
Geronimo36
Also, like Jimmy said you may also need the yoke but you wont know until you get it apart. If there is a tiny groove in the yoke you can buff it out with wet sand paper, if it's deep it's garbage.
I have used a big outside spanner wrench that you can get from graingers and a dead blow to get them apart BUT you may knock a notch or a tooth off the retainer if your not careful. A little heat doesn't hurt euither if its the first time its ever been apart.I used to use a breaker bar and k/d brand gm ac adjusting tool to get them apart and use the same tool with a torque qrench to reassemble them but the spanner works better. I put them back together with the chrome moly steel retainer that max machine worx sells,its pretty durable vs the stock aluminum,Smitty
the 1apc6 fits the best
http://www.grainger.com/Grainger/wwg...=19&submit.y=7
