Transom Assembly Grease/Lube
Doing the final assembly on my speedmaster transom assemblies and wonder what you guys are using for lube/grease on the hinge pins. Merc manual calls out for a 50/50 mixture of Merc anti-corrosion grease and "high pressure" grease. They reference the high pressure grease with a Chicago manufacture I couldn't find. I have seen guys use the Merc green(don't know which one that is) on bearing surfaces too. I'm not in salt water, so whatever gives me the best lubrication is what I am looking for. Thanks in advance.
Jim
Jim
