Bravo - 2000 upper fit a 1988 gimble housing
The 2000 drive has provisions for an oil reservoir bottle in the engine room, and the 88 transom does not. Rumor was there is a kit out there to update the transom assembly.
Hope that helps.
Jim
Hope that helps.
Jim
Charter Member #601
If you are swapping a B1 for a B1 it will fit, as far as I know the reservoir bottle is the only issue. The input to the drive itself should seal because of the ball and seat that is normally pushed in by the fitting on the newer transoms.
If you are looking at swaping an XR drive on, then see the thread about the Bravo Drive Compatibility.. for issues with input shaft differences..
Hope this helps
Dick
Hope this helps
Dick
