TRS Prop shaft
Registered User
Yes, requires special tools and some degree of skill & experience.
Best advice- take it to someone well-experienced with the TRS in your area. Be prepared for it needing more than you planned. It doesn't always work out that way, but mostly.
Geronimo36
I may have a propshaft laying around if you need one!
If you reuse the bearings and races it's higly likely that it won't need to be re-shimmed but is has to be checked anyway.
If you want the shaft send me a PM and I'll go check the storage shed and see if I still have it. I believe I also have a verticle shaft, ujoints, pinion shaft and drive shaft.
Frank
Frank
Geronimo36
Here's what I have of my TRS stuff.... I'll take offers...
1. Case - needs the edges of the carrier threads welded.
2. Propshaft - good condidtion
3. lower vertical shaft - good condition
4. upper pinion shaft - overall good but needs a speed sleeve over the seal area.
5. input shaft - good condition
Geronimo36
FYI, the Propshaft is for standard rotation TRS and drive gear splines are at the end of the shaft. I believe the Merc PN is 44-92327T1
Oh yeah, if you re-use your existing lower gear/bearing you will not have to reshim the gears, you will just need to properly adjust the propshaft pre-load when installing the propshaft carrier. You should also replace the bearing on this shaft as it's sat for a while.
tomas_wallin
7
01-12-2006 01:28 PM
MIKEHTMSR24
07-22-2002 03:18 PM
