sportmaster lower can't get out of forward
have a problem with my 225 promax with sportmaster lower.can't get it out of forward with the engine running.as soon as i shut the motor off it comes out of gear.no problem with reverse only forward.no grind noise,shifter just won't move.what could be wrong?
check linkage on engine under cowling on left side may be loose or hanging up. also check the bushing which centers the shift sahft in the adapter plate for wear.
if not could be the clutch dog on the forward gear, especially if your running big pitch.
spinning 32" props.i checked all linkage with no problems.i will look for that switch.if it is the clutch dog can i run the boat?i think this will be my last weekend for the year
Jason
any of the big pitch outboards i set up , i bypassed the neutral safety switch with an over ride momentary button. this way you can shut the engine off , shift in to gear then start in gear to avoid prematurely hand grendeing the unit.
i would say if you have no big amounts of metalic or material in the oil or its not burnt then you should be able to finish the seasdon.
Smarty
13
06-17-2007 11:08 AM
