stern jack or longer shift cable for a bravo drive
Does anyone know where I could get a shift cable for a stern jack setup on a bravo drive? They are about 9"s longer than a stock shift cable. What do you use on a bravo with extension boxes?
I've got standard lower cables with Stellings boxes and my engines are moved forward a foot. The standard lower cable is just barely long enough. My shifter linkage is mounted in the standard place on the headers.
If you have problems, you can always mount the shifter linkage on the transom.
The deal with the stern jack box is that it uses a 8-9" longer inner cable, The outer is the same length. I havent had any dealings with stand off boxes, So I didn't know what they used for a shift cable. It suprises me that you can use a stock cable with them. What do you have to do with your trim hoses,? Do you have to move the pump closer or longer hoses? I have someone that is talking about putting boxes on his 38 special, So I may be asking for alot of advice later this fall. Thanks
I have a complete SJ for a bravo one for $1200 if you know anyone who needs one.
DrFeelgood
Drives and Lower Units
5
11-05-2007 09:42 AM
