Difference between #4 speedmaster & #5 >
Old 01-03-2015, 01:51 PM
Received 1,892 Likes on 951 Posts
An SSM IV is a shorty 3. An SSM V is shorty 3A.
Griff is offline
Old 01-03-2015, 02:02 PM
I don't think that is correct. Larger gear sets . You can't handle more hp just because the drive is shorter. The higher the # the more hp you candle, that's the simple way to explain it .
cig92 is offline
Old 01-03-2015, 03:00 PM
The vertical shafts could take more torque being shorter
Unlimited jd is offline
Old 01-04-2015, 01:06 PM
RMPRam's Avatar
The #3 and #3A are basically the "same number", but way different in internal construction. The #3A has the same straight cut, near net forged upper gear set as the #5 and the same propshaft (1.75" dia.) and lower gears as the #5. The #3 and the "shorter" surfacing #4, share, basically the same internal components. In my opinion, the "weakest" of the four drives is a #3 followed by the #4, then the #3A and #5 are the same strength, but the #5 is the "surfacing" version of that set.
RMPRam is offline
BOATMAN302
Ocean Express
6
03-22-2008 12:19 PM
CNC
3
11-17-2004 06:36 PM
Velocity Tom
03-09-2004 08:04 PM
Wild
06-19-2002 04:07 PM
formula233
04-28-2002 10:40 AM
Quick Reply: Difference between #4 speedmaster & #5
