Difference between #4 speedmaster & #5
speel chekk this fokker!
i though the ssm5 drive had the very long skeg and the bullet was higher resulting in your prop (raised x-dim) being higher?
Pardon me, while I whip this out!
GOT MERC?
![Cool](/forums/images/icons/icon6.gif)
The diff is,
The actual measurement from input shaft to prop shaft on a #4 to #5 is the same. The only external difference is the length of the lower housing. The internal components are alot stronger in a #5 SSM versus A #4 SSM. If you want more info give me a jingle I will let you talk to the first man to build a SSM for Carl Kiekahfer. He works for us
Can you tell me the size difference of the external length of the lower housing. For ex: length of the #4 and #5.
Im going out to look at a boat this weekend That was to have #5"s on it, But I am hearing rumors that the drives were swithced over to #4's and I have no clue what to look for.
Your help is really appreciated!!
Thank you!!
The diff is,
Thank you!!
The diff is,
Offshoreonly Advertiser
Not sure about the housing differance, but the hole for the tilt pin is 1" on a #5, 7/8 on a #4, but of course it is possible it has been drilled out.
Marc
www.mercruiserparts.com
www.go-fast.com
www.bammarine.com
www.cyborgtransmissions.com
It's not alive -www.BoatStuffExpress.com - temporarily retired
Marc
www.go-fast.com
www.bammarine.com
