Shorty on Baja Sport 250?
Getting ready to do some upgrades on my Baja. Thinking I need a -2 shorty. These old Bajas are very deep. Around 8" if I am measuring the correct way. Has anyone ever run one of these on this particular hull? What can I expect? Boat is an 89 250 ES Sport. Current hp. Is 500. Bravo 1 drive. 70.2 mph. What do you guys think?
not a 250, but i had a 240 with a minus 2" imco. boat was great. had 630 hp ran about 78-79 loaded.
no ill handling and planed great with a box stock bravo 1 26" 4 blade.
http://www.youtube.com/watch?v=BgvcJrTiCLE
Seems like any of the older hulls do better with a raised X. I have seen 320's and 280's that both did well with it. I would think the 250 should work well with it also.
Thanks guys, sounds like a shorty is in the making then! Seems like I had read on here somewhere that this hull needed bow lift and shortening the drive would not help with that. Therefore it was not the right move. Lil Red, your 240 looked great. Look like it was handling great. Mine doesn't handle that good, and only run 70 . Maybe the shorty will make mine do better and pick up a little bit. What do you think, maybe 2 or 3 mph. ?
Bit more work than a shorty but well worth it in the end. Gives much better leverage to carry the bow and reduces the amount of trim needed.
i am just curious on what prop you are running to get up to 70 off 500hp? i am 50hp behind you and best of 63 gps in the same boat. i am running a mirage+ 23 at 5000rpm right now. i am adding edelbrock heads this year, hoping to get closer to that 70 mark . i am also curious to see results of a shorty or extension box on this hull. the hull is nearly identical to a 25 outlaw so keep that in mind when searching for options
