99 baja 302 bravo one outdrive oil service question please
Hello guy I am a long time follower and finally purchase a 1999 30ft baja boss 302 with bravo one out drives. When I service the out drives should I do it like this
1. Remove fill/drain plug in bottom and remove top check plug as well
2.let drain over night so it will drain my monitor as well?
3. Use the special pump and fill thru bottom hole until I see it run out the top hole?
4. Then reinstall the top plug and leave the pump hooked up to the bottom one.
5. Keep pumping more in until the monitor has around 1" of oil then top off to the full mark?
Please let me know what you think I under stand lots of threads adress this but I'm still curious about the monitor complete drain!!!! Thanks guys!!!!
some one? any one?? haha im starting on it here in a few minutes and would like a little insight on this matter????? most of my worry is with filling thew monitor???please some one chime in and help me... Im new to the forum and was hoping to get a hand of addvice, tricks etc guys
so should i just take monitor off and dump the gear oil out of it??? Dont want old fluid in the resv or the line i want all new??? also i was told i need to remove the bravo 1 prop in order to drain??? im think 1 1/16 size socket???? do i need to remove hub also?
Thanks for your input but it's wrong.. The bravo one is not like the 3 or the alpha. Drain/fill is behind the prop pal... All good I just can't find anywhere on hoe to take this apart
I put a clip on my reservior line, so the GOOD UNUSED fluid does not drain back down into the drive when I change out the fluid! I pull my prop off, then remove bottom drain/fill screw, then remove upper vent screw. I then pump lower unit until fluid seeps out, then replace vent screw and give it about ten more pumps and put the drain/fill screw back in. I then unclip the resivior line and let it sit for a few hours and recheck the reservoir level and top off if needed and then always recheck it after out on the water and its ran for a few minutes. The screw is easily accessible with the prop off and the plastic hub pulled off, it should come off fairly easy if it has been lightly greased before it was put back on in the past.Mine have always come off by pulling by hand.
