Bravo 1 top gear set change procedure
Can somebody help looking for a procedure on how to change broke a few teeth on the upper gear set the gear below the clutch do I change them all or just the one that is chipped also thx
You'll want to disassemble the lower and clean out the fragments that migrated south
I hate the winter!!
You cant simply change the gears. The new set must be set up correctly. The job requires a few special tools from Merc. Not particularly difficult to do, just needs to be done right. I agree, the lower needs to be taken apart to be checked and cleaned out of debris.
