Trim Limit and Trim Position switch adjustment >
Old 07-14-2013, 10:38 PM
Default Trim Limit and Trim Position switch adjustment
I adjusted the two 'hockey puck' trim units on my Bravo III outdrives. Two of them had extremely tight screws. One screw actually broke off as I loosened it.
How tight are these normally?
glboatdriver is offline
Old 07-15-2013, 09:04 PM
they are not tight, they are corroded in. pretty common as they are two differnt metals and the aluminum corrodes a little and locks them in.
compedgemarine is offline
Old 07-15-2013, 09:25 PM
Makes sense. I'll end up replacing several next time I'm wrenching on the boat.
Should I try any anti-seize compound, or just let them be figuring they will be set where they need to be?
Thanks!
