Land and Sea Stern Jack >
Old 10-13-2017, 04:18 PM
  #51
so you had them on your 32 and liked them ? better ride at high speeds ?
twestedsticks is offline
Old 10-13-2017, 05:36 PM
  #52
No only had 1 on 24 outlaw. The 32 didn't need any help . But both boats always ran with tabs dipped to keep from launching off any waves and heading for the sky. Lol
veloc410 is offline
Old 10-13-2017, 05:38 PM
  #53
The stern Jack will allow higher drive height but your still tipping the drive up at an angle to do it
veloc410 is offline
Old 10-15-2017, 07:39 PM
  #54
Originally Posted by twestedsticks
Trying to keep my front down , and barely found these two ,the guy on ebay wants 3 times as much as the ones I found , just wondering if the boat will be faster and I can take out the 400lbs of sandbags i have shoved up front.
now I'm thinking you didn't really add weight to the front. Correct
veloc410 is offline
Old 10-16-2017, 01:18 AM
  #55
Yes had to ,, to keep the front end down in big water , works great , had to research it , thats what they did back in the day of this boat .
Old 10-16-2017, 09:29 AM
  #56
You have twins right. If you turn your props out . The bow will stay down or at least be controllable. Then you can lose some wieght.
veloc410 is offline
Old 10-16-2017, 09:48 AM
  #57
Hopefully you don't have counter rotating engines. That would be a little tuffer. Lol
veloc410 is offline
Old 10-17-2017, 01:15 AM
  #58
LOL yes there counter rotating props but not counter rotating engines , that's ok I hope ???
Old 10-17-2017, 08:35 AM
  #59
Can you Switch the props and run them in the opposite direction they should be spinnng out at the top of the propsThat will give you Stern lift which will help keep your bow down
veloc410 is offline
Old 10-17-2017, 02:03 PM
  #60
yes sir they are spinning out words , thanks for having me check to make sure
