changing a 1 inch shaft to 1.25 inch on bravo one >
Old 07-13-2016, 12:48 PM
Default changing a 1 inch shaft to 1.25 inch on bravo one
is this a hard install? was gonna upgrade the shaft because i dont want to go loosing a prop! lol was gonna order from cpperformance http://www.cpperformance.com/p-15739...rsion-kit.aspx
daniel475 is offline
Old 07-13-2016, 06:14 PM
Offshoreonly Advertiser
Mbam's Avatar
It's not too bad, but you should have a shop manual to guide you. I see that kit uses the original gears, that will save some work.
Mercury makes a kit also which includes new lower gears as the shaft diameter is larger all the way to the spline. With the Mercury kit you have to shim both the pinion depth and set the backlash on the driven gear.
http://www.mercruiserparts.com/84037...pshaft-kt-brav
Mbam is offline
Old 07-13-2016, 08:14 PM
How are you worried about losing a prop? Shaft snapping ?
class6 is offline
Old 07-26-2016, 11:36 AM
articfriends's Avatar
IF it doesnt use the bigger radius going into the gear I wouldnt bother, you would be better to pull gear and bore it out or buy a new one and use the even beefier shaft, the reason why I say this is when I sheared off a prop shaft it broke in that spot, fwiw, Smitty
Attached Thumbnails changing a 1 inch shaft to 1.25 inch on bravo one-dsc04706.jpg
articfriends is offline
Old 07-26-2016, 11:38 AM
Stock gears can be bored out IF they are perfect otherwise, I do it all the time
Attached Thumbnails changing a 1 inch shaft to 1.25 inch on bravo one-dsc04701.jpg   changing a 1 inch shaft to 1.25 inch on bravo one-dsc04705.jpg   changing a 1 inch shaft to 1.25 inch on bravo one-dsc04702.jpg
