1990 bravo 1 side to side play, bad gimbal ring?
I can supply a video to show but there’s a 3” play on each side when I wiggle the outdrive. The shaft pin is good, no vertical movement on the outdrive. The steering arm doesn’t move. Should I go ahead and buy a new transom assembly because of a bad gimbal ring. Part is on back order, need to place an order ASAP if the gimbal is worn.
https://youtube.com/shorts/s14g4RoONg8?si=R-TGUnfuOmlWmi8e
Put hydraulic steering after fixing what's needed
PQ290Enticer (07-12-2024)
