Washer stack sequence
Hi,
What's the proper.proper stack
on these showers foe my Bravo One XR Sportmaster? This is the way they came off, but doesn't mean they're correct.
. The two same diameter ones, one is slightly thinner than the other. Didn't put calipers on it, but can tell.
Thanks!
Thanks!
The bellvue washer should be in the middle, not the end. In other words the washer that has a curve in it should be in the middle.
imartin (06-28-2024)
The washer that is not “flat” goes in the middle. I can take a pic of the instructions if you need that.
imartin (06-16-2024)
