What is the best tool to cut speaker openings?
If you are worried about vinyl, trace your opening with a pencil and then use a razor, but go SLOOOOOOOWWWWWWWLLLLLLLY.
Forum Regulator
Keith:
http://www.offshoreonly.com/forums/f...aker-hole.html
http://www.offshoreonly.com/forums/g...remel-one.html
http://www.offshoreonly.com/forums/a...iberglass.html
Also, have a second pair of hands there; specifically holding the shop vac right behind your cut.
Vibrating cutter... Take your time.... Lots less dust!!
http://m.lowes.com/pd/PORTER-CABLE-3...ol-Kit/3851689
is this what you mean?
https://www.youtube.com/watch?v=VpSgKfYASGk
I
Hey Brian,
Thanks for the threads, appreciate them.
I will upgrade the stereo in the AT.
2 - 10 inch subs
2 - 8.8 coaxials
2 - 7.7 coaxials
2 - tweeters
1 - MHD 900/5 amp
All JL Audio and M series speakers. I'll start with this and see how it is and if need be ill add more later.
[ATTACH=CONFIG]531999[/ATTACH]
Keith:
2 - 10 inch subs
2 - 8.8 coaxials
2 - 7.7 coaxials
2 - tweeters
1 - MHD 900/5 amp
For me it really depends on the hole I have to cut and the area I have to cut in. Whenever possible I use a hole saw of the right size. 10" hole saws are pretty expensive, so I will use a jig saw or a rotozip for those.
I
Hey Brian,
2 - 10 inch subs
2 - 8.8 coaxials
2 - 7.7 coaxials
2 - tweeters
1 - MHD 900/5 amp
Hey Brian,
2 - 10 inch subs
2 - 8.8 coaxials
2 - 7.7 coaxials
2 - tweeters
1 - MHD 900/5 amp
That system you have right there should make plenty of sound. The 10" may have a bit of a hard time keeping up with the four coaxial speakers, but should add some solid bass to the system.
