Stop salt corrosion on wiring
Corrosion in and on internal wires only adds a bunch of resistance - in return this heats up the wiring and what connected to. If all possible you could make proper splices or will have to replace/. Also as the wire corrodes it get thinner - the thinner the proper recommend gauge wire becomes the more resistance is produces along with heat..
The dielectric grease general motors used to put out for service in the cadillac line is some of t
he best i have seen . Dont smoke a cig after handling or you will be one sick mo fo .
for smaller connectors or applications the new brown dielectric is the way to go . The gm pasty stuff will stand up to powerwashing ect the brown wont .
