Head Units with Memory......
I ran a small memory wire directly to the battery and have had zero problems from it even when stored for 4-5 months. Stereo memory draw is only .007ma, so on a typical boat battery of 800 cca it will take 4762 days, or 13 years, to drain the battery to zero. At that point you should've sold the boat anyways.
I ended up buying the JL Media Master. It does have the eeprom feature. Not hooked up yet, but it appears to be a little easier to use (intuitive) than the single din Sony it is replacing.
