Softwareupdate Vesselview 1.5
Hi,
My vv crash after a few secounds runtime.
The first 5 secounds my vv works great then the Display freeze .
Ater a reset it works again for 5 secounds.
It startet after i have select a wrong engine in the settings.
The 5 secounds are not enough to change it to the right engine.
So i am hoping that a new Software can fix it.
Annyboady know how to make a update and have the Software.
Christian
Christian
Vessel View 1.5 freeze
Hi Christian,
I just found your post looking for the solution for the same problem I have experienced. I was trying to install a new device and probably had some previous setting which makes it freeze after about 5 sec which is not enough time to go to factory reset option.
Did you manage to solve the problem and how?
Regards,
Dragan
Regards,
Dragan
