Mobile vessel view
simrad, I would get the link, then you will have the OEM vessel view interface biggest factor here is the warnings, not just a generic "fault", but you will get an "injector fault" . i would suggest find your local mercury dealer and start a relation with them... I get a very generous discount from my dealer cause i said i will sped x amount with you on a yearly basis can you help me out, still can find it cheaper online but because of the business/relationship i can call and ask any questions i'v borrowed shop manuals from them etc. that is worth a little more.... otherwise the part numbers are in the pdf below and befriend your self with google....
https://embed.widencdn.net/pdf/plus/...b.pdf?u=orhjei
im in the process of going digital on my gauges .I have a 34 Fountain with triple 300xs at the moment on simrads. I purchased the gateway ( not knowing any better) but have read that the vessel view link is way better The gateway seems very generic and plain.. any advice is appreciated.. also where is the best place to purchase the vessel view link multi engine from?? thanks
Would love to see more pics of your fountain!
did you go through the full set up procedure?
mine works great but every now and then I need to reset the connection using some app called light blue. It fixes Connection issues.
It does not sound like you are connected
In not sure if it goes through the full set up procedure
