Fuel pump relay question
2000 Baja gen6 502. Aeromotive A750 external pump.
I am not getting power to my fuel pump. My relay is getting 12v but the pump wire is 0 voltage. I should here the pump turn on when the key is turned to acc? Thank for help.
EFI ?? there should be a connector with a gray ? cap on it on the rear of the engine, pull the cap and you should see 3 fuses, one it for the fuel pump if this is a stock wiring harness
From what you've described it sounds like the fuel pump relay itself is bad or there is a break in the wire running from the relay to the pump. The relay's aren't that expensive. It might be worthwhile to get one. If the problem is elsewhere you'd have a spare. You could check out the wire connection using an ohm meter and a length of wire.
