Audio Upgrades
#41
Originally Posted by [email protected]
That looks great Brad, I agree even with the JL's being an infinite baffle subwoofer you cannot beat the performance of a sub with a full enclosure. I do like the idea of using the bazooka tube setup and i'm thinking I would have enough room to get away with that in my side pockets aswell.
If you decide to go that route, don't get carried away. One 8" is P-L-E-N-T-Y. I've got mine turned down to about 1.5-2 on the volume, and (I think) -6dB bass in the head unit, and, along with four 6.5 3-way rounds, it sounds awesome while we're swimming, and will run you out of the cockpit at full volume. It's a powered sub tube, so no need for high current speaker wires or separate amp; just RCAs. It shakes and thumps the hull, but nothing rattles, because it's not contained.
Thanks. Brad.
(937)545-8991
[email protected] (01-12-2022)
[email protected] (01-20-2022)
#43
I just installed an entire JL system in my boat.
6 - M6 7.7's
1 - M6 10" sub
1- M600/6 amp
1- M600/1 sub amp
The system sounds amazing other than the bass. 1 10" open air sub is not nearly enough. I already want to re-glass under my rear bench and add 1 or 2 more subs.
6 - M6 7.7's
1 - M6 10" sub
1- M600/6 amp
1- M600/1 sub amp
#44
I’d seriously suggest Bazooka tubes. I’d venture to say that a single 10” powered tube would be more than enough. If it isn’t, two will be.
As I said, I have a single 8”, which is the lower power option they offer (they have a 100W and a 300W, I think), I’ve only got it at about 1.5-2 on the output volume, and the bass set at (I think) -6dB in the head unit, and it’s absolutely plenty.
Thanks. Brad
(947)545-8991
#45
My last boat I put the one JL 10" sub and 6 of the 7.7s....it was more than enough sound for me and sounded great. I did run one JL amp for the 7.7s and one 600w separately for the sub. Their amps were nice and compact and I had to run the sub amp turned way down about half. I don't need to be the loudest boat in the tie up but it had enough bass to shake stuff apart and was louder than anyone could handle.
My new Formula has the factory installed JL sub and either Clarion or Memphis 6.5s...I can't tell and haven't taken them out.. It has 1 Memphis Audio amp powering 6 of the 6.5s and the sub on a 300w channel. It sounds good and clear but is not nearly as powerful. I'll probably replace those with the JL 7.7s if there is room.
Has anyone gone from a base M3 JL sub up to an M7 without an enclosure and noticed a difference?
Formula 353
Merc Racing 540s
Formula 353
Merc Racing 540s
#46
Anyone have an idea how long 2- 150 reserve capacity batteries will run a 2300watt system?
internet is all over the map from 15 minutes to almost 2.5 hours. I would never play at full power for very long, but I figure if I can calculate it at full volume, then I have more time than that at lower volume levels.
#47
I went Kicker in my Baja 342. The same set up in JL would have been nearly twice the money. I have heard JL systems in other boats and they are crystal clear and powerful. The other reason besides price was availability, the best is in high demand and a lot of stuff was back ordered indefinitely. Hopefully my mid level system sounds good, still waiting for a few things to arrive so I can get started. the 8s and the 6.5s holes were pre determined by the previous owner. the installation was top level, I just cant understand why anyone would go to that trouble for a very cheap china system. I will be pulling all new wires and doing a relocate for the amps and 3rd Battery. Subs are going in the rear bench, wish I had gone with 10s, my life would be easier. System is
Kenwood deck
2- 12" free air subs
6- 8"
4- 6.5"
1200watt sub amp
600 watt 6 channel (8s)
450 watt 4 channel (6.5s)
LEDs in all speakers with a controller
wired helm remote
I am gonna install a 2nd deck and 4ch w/ 4- 7.7 down in the cabin( recycling the china system).
Kenwood deck
6- 8"
4- 6.5"
1200watt sub amp
wired helm remote
#48
I had 2 M6 10's in a sealed box (1 cu ft) with a M 600/1 and wasn't thrilled with the output. It did OK.
I now have 1 M7 12" in a sealed box (3 cu ft) with a MHD 750/1 and it shakes the emblem in my steering wheel. Way more output than the 2 10's
Truth be told, I'm a bass head and would LOVE to have 2 of the 12's installed. The 3 cu ft box is pretty big and takes up some space. If you do a free air application, I've read it's very important that the back side of the woofer is sealed air tight from the front.
Link to a short vid of the sub in action.
#49
I actually had 2 - 12" subs in enclosures in my engine compartment that where in the boat when I bought it. I went to 2 - 10" M3's under the back seat and they actually sounded much better. I had to turn them down as they were so overpowering. It seems the under seat volume is perfect for the 10's and the M3's work well for this application.
#50
I'm not a bass head by any means but it isn't nearly enough. It was to the point I actually had to check and make sure the cone was actually moving.
I set the gain/sensitivity per JL's manual using a multimeter as well.
I'm beginning to wonder if something may be wrong with it.
