Go Back  Offshoreonly.com > Technical > Electronics
daytona sensors Coil mount >
Old 10-13-2022, 12:13 PM
This is how our coil is mounted to our ignition box bracket
chancer540 is offline
Old 10-13-2022, 07:39 PM
seafordguy's Avatar
Originally Posted by SABER28
the problem with mounting that ignition box vertically is that those little rubber isolators are not designed to support that much weight especially the pounding a boat takes.
Hadn't thought of that. Been a couple seasons but I'm going to check them. Luckily I'm a fair weather boater that drives like a grandmother....
seafordguy is offline
resurrected (10-14-2022)
Old 10-14-2022, 08:31 AM
I mounted my box on the transom so it wouldn't have to endure the engine vibration and put the coil on a plate that had my old MSD coil on the back of the even bank cylinder head. 3rd season and no issues.
ThisIsLivin is offline
Old 10-15-2022, 11:42 AM
Rookie's Avatar
Received 1,248 Likes on 604 Posts
I mounted my box and coil on the transom. This is where they will see less impact and jarring. Same place I mounted my ECU's now that I went with EFI.
Rookie is offline
