Help - dual drive rocker switch wiring
Can someone help me with how the rocker switches for dual drive tilt should be wired along with a trailer switch and throttle tilt?
I’ve seen every schematic online but nothing shows how all of the poles on the back of the rocker switches should be jumped.
Were doomed!
I can draw one up for you a little later unless someone happens to have it they can post up here before i get it done
I'm assuming the trailer switch would be on the transom somewhere? And your throttle tilt would be two switches...one for each drive? or just a single for both?
-Wally
-Wally
Were doomed!
are you trying to use the same switches or planning on getting new ones? If same then i'd need to see what the switches look like from behind to verify what they are......the trailer switch is the same as "Both" on most other offshore boats.....
-Wally
-Wally
Were doomed!
here's a quick job i did assuming you were starting from scratch and didnt have any switches to use.
SPDT = Single Pole Double Throw switch
DPDT = Double Pole Double Throw switch
The middle one on your dash switchs below would also be the "Trailer" switch in your case so just ignore the other one below....that would have been on the transom or the like if you had that option.
-Wally
-Wally
thanks - using existing. I believe they have 6 prongs on the back of each but will try to get a pic this weekend and come back. Appreciate you jumping in.
Were doomed!
If they all have six prongs then they are the DPDT type...you dont have to use all six spots for the switch to work. You can run one side of a switch and have the other side for a backup in case the contacts go bad
-Wally
-Wally
Were doomed!
You would need to contact who ever made the switches to see what the pin's do. I'd venture to guess they are the Carling Switches https://www.carlingtech.com/rocker-switches-sealed
So if i had to guess, then its a double pole / double throw switch, so each side has 3 pins that would run to the trim pumps. Then the other two pins would be for a ground and a power wire for the light inside the rocker to light up. But not knowing what they are exactly its next to impossible to say for sure. You would need to look at the switches and get some part numbers off them or something to find what exactly they are and how to wire them up properly.....
-Wally
-Wally
