Hawk setup questions
I am rerigging txhawk's old 40, it will not have boxes anymore,
Standard 1.50 ratio bravo 1 drives and 590 flywheel hp hawk big blocks with small blowers.
What is a good prop for this hull? This one does have a notched transom. I was thinking a 26p bravo 1? Anyone have any thoughts or input?
Good luck, it definitely is a wave crusher and should run real well! I've wanted one for a while.
Everything is for sale
Here's some pics of the work i've done over the last month
degreased and painted the bilge removed the extenxion boxes, repaired the transom after removing the boxes and tried something to see how it broke up the white. went to install the engines and found the alignment was way off so i had to plug and redrill the holes in the stringers. then start rigging everything back and set up the new power
both engines are in now drives are on, just have to mount the new steering brackets and make some adapters for the air cleaner/flame arrestors may posibly shake it down this weekend or a day next week
that scarab is built like a tank !
