boat painting 101
#211
Neno the mind boggler
yea Tim . . .that is the place around here. . .
OK . . . i have some update stuff. heres some pics of filling in the gauges. luckily Sean clearly marked out everything that needed to be filled but somehow i still missed the indicator hole
pretty straight forward stuff. cut some plugs out of the same thickness plywood to fill in the holes. i lay a piece of tape tape behind the hole to hold the plug while its curing. coat the entire plug with epoxy and pop it in than fill the perimeter gap with an epoxy/404 mix. at the surface i used a single layer of 1808 bi-ax cut slightly larger than the plug. i beveled back the holes about a half inch.
![Drink](/forums/images/smilies/drink.gif)
![Roll Eyes (Sarcastic)](/forums/images/smilies/rolleyes.gif)
08 OPA High Points Champion
#212
nice . . started a whole new page to get back on track . . whatever that is
#213
after its cured grind the surface down and fill any small air voids with a skim coat of a light filler. i use evercoats "metal glaze" but only for minor stuff. do all your major stuff with the west systems. finish sand and and prime
![Cool](/forums/images/smilies/cool.gif)
#214
some general update pics for all you non believers
#215
Sean was late getting up here an he said he was having car trouble
. . .guess he was luckey he made it at all
. . . some how he towed it up here with this thing
![EEK!](/forums/images/smilies/eek.gif)
![Stick Out Tongue](/forums/images/smilies/tongue.gif)
#216
OK . . i'm off to do some research on color theory and contour line definition
#217
. . . some how he towed it up here with this thing ![Stick Out Tongue](/forums/images/smilies/tongue.gif)
Thats an upgrade from his last rig.....
![Evil](/forums/images/smilies/evilB.gif)
#218
I'd rather be boating!
some general update pics for all you non believers ![Drink](/forums/images/smilies/drink.gif)
Both of us now have the utmost respect for glassdave, grafikworks and all of the others i can't remember after an evening of paint fumes. What they do is an artform and takes a great deal of skill, education, dedication, pride.....the list goes on and on.....
Thanks for sharing some of your work with us!
#219
thanks for the compliment inbetween. how is your project coming and do you have any pics?
