boat painting 101
#273
Neno the mind boggler
yep
after i tuned up the leading edge of the riser i cut the remaining inside portion out than sanded it all smooth with 40 grit. after that it is covered in two layers of 1808 bi-ax on all sides. all edges must be radiused to about 3/8th of an inch to allow the laminations to make the bend. i use west systems for just about everything and i mix catylist by weight, 22% for epoxy.
08 OPA High Points Champion
#274
place part in high-tech baking over for best cure out.
#275
after its completly cured ity can be sanded down with 40 grit to rough in the desired shape. than it is faired out with westsystems low density filler. this takes care of any air voids and allows you to sharpen up the edges.
#276
during the fairing process the part is test fit about a million times
#277
once i have its shape about 90% where i want it, it is bonded to the deck with . . .you guessed it . . .MORE WEST SYSTEMS!
. the final bit of shaping will be done when the rear extensions are bonded.
#278
Sean- what do you think of thisa for the deck hatch? heres a linkboatersworld.com
#280
I saw on the list of projects " filling snap holes" ... I assume that ...or was for the cockpit cover ? If so ..do you rely on a full cover ? .. I hate all those snaps on my 311 .....
