boat painting 101
#62
A to Z
now i am getting bashed in a thread about my boat being painted....
even worse, buy a guy with a gold chain and a black satin jogging suit...
![Roll Eyes (Sarcastic)](/forums/images/smilies/rolleyes.gif)
#63
even worse, buy a guy with a gold chain and a black satin jogging suit... ![Big Grin](/forums/images/smilies/biggrin.gif)
#64
Great thread, comedy and knowledge!
This is the first thread I check when I log on!!
". third option is the good old bullet technique, and a long reach. which im sure your familiar with."
What's the bullet method?
Thanks So Much!
DS
Thanks So Much!
DS
#65
Neno the mind boggler
Thanks So Much!
DS
Thanks So Much!
DS
![Drink](/forums/images/smilies/drink.gif)
bullet technique is turning up the fluid as far as it can go and shooting from a few feet away. sometimes helps
if you narrow the patern as well. you can shoot fro a few feet awy like this.
08 OPA High Points Champion
#66
yea . .this thread is go'n in all kinds of directions
#67
Originally Posted by hillbilly24
Followed by alot of wetsanding and buffing
![Cool](/forums/images/smilies/cool.gif)
#69
How many coats of clear do you usually spray on a boat? Also, what grit of sandpaper do you use to sand after the clear coat? Wet sand or dry sand the clear coat?
#70
Remember boys and girls, using the bullet technique with a spray gun is ONLY for the DECK, do not try it on the sides. you will have icicles hanging from the chine of your boat. lol we use this method only to reach across a wide area like a Cat deck. you adjust the gun to spray in a round pattern instead of a fan pattern, this will blast the clear out about 3-4 ft from the gun. it goes on very heavy, but for the deck thats ok because it wont run. just be careful around the wind screen or hatches.( recommended for trained professionals only.)
