Go Back  Offshoreonly.com > Technical > Fiberglass and Paint
boat painting 101 >
boat painting 101
boat painting 101
Old 04-28-2005, 09:17 PM
  #71
grafikworx's Avatar
Default Re: boat painting 101
Originally Posted by H20 Cowgirl
How many coats of clear do you usually spray on a boat? Also, what grit of sandpaper do you use to sand after the clear coat? Wet sand or dry sand the clear coat?
as many as you can stand. no really 3-7 coats depending if you are trying to just clear over base-coat for gloss, or if you want to submerge the graphics to a flat smooth finish. you can also clear, then sand the next day and clear again for very flat finish, depending on your wallet.
grafikworx is offline
Old 04-28-2005, 11:13 PM
  #72
masher44's Avatar
Dave has the first coat on.....
masher44 is offline
Old 04-29-2005, 05:34 AM
  #73
offshoredrillin's Avatar
Received 1,297 Likes on 449 Posts
Now that there is funny, I dont care who ya are
offshoredrillin is offline
Old 04-29-2005, 06:29 AM
  #74
A to Z
Sean H's Avatar
masher told me your boats are scared of the water......
Sean H is offline
Old 04-29-2005, 06:59 AM
  #75
rv
grafikworx/glassdave,
You indicated that you put multiple coats of clear on then sand then put another coat of clear after that. Is that a better finish than sanding and buffing out on the last coat? It seems to me the sanding and buffing will give a true flat surface. When you spray again after sanding isn't there some level of orange peel effect?
Rick
rv is offline
Old 04-29-2005, 07:08 AM
  #76
tssteph's Avatar
There will still be a sand and buff at the end. base, then clear, sand, then clear, then sand and buff.
Gets rid of tape edges/graphic lines.
tssteph is offline
Old 04-29-2005, 07:22 AM
  #77
H20 Cowgirl's Avatar
So after the last coat of clear I assume you wet sand, right? With what grit of sandpaper? Do you use a rubbing compound when buffing? If so, what's the best kind? I'm asking because a friend painted my boat and it looks awesome, but it kind of looks like it could use a buffing to bring out some shine. I did all the sanding/prep work before he painted and now it's up to me to finish this job. I don't want mess up the paint job.
H20 Cowgirl is offline
Old 04-29-2005, 07:32 AM
  #78
tssteph's Avatar
Others (professionals) can chime in, but it depends on the paint material used. I normally use 1500 wet. Looks like glassdave dry sands with 1200 on a DA, I have never tried this. I have a waterbug DA and use 1500 on it. All of my experience is with vintage Corvettes but finish steps are the same. I user Perfectit 2 and 3 and then a hand glaze. I would also be interested in what the "pros" use.
Before and after of the last job I completed:
Attached Thumbnails boat painting 101-pic00001.jpg   boat painting 101-pic00001.jpg
tssteph is offline
Old 04-29-2005, 07:36 AM
  #79
tssteph's Avatar
Another:
Attached Thumbnails boat painting 101-pb020004.jpg   boat painting 101-gm57_002.sized.jpg
tssteph is offline
Old 04-29-2005, 07:49 AM
  #80
grafikworx's Avatar
yes what he said.
Hey nobody said it was easy.!!! Painting boats like these is a lot or work.
Quick Reply: boat painting 101
