Go Back  Offshoreonly.com > Technical > Fiberglass and Paint
Windshield glass removal >
Old 07-29-2005, 05:07 PM
Default Windshield glass removal
I have an old school boat with the 4 piece windshield that slides together....aluminum frame. I'm going to cut the frame lower and use plexi in the frame bases. How do I get the glass out without using a hammer? Was the frame built and welded with the glass in place or can I get the glass out by removing the rubber strips around the glass?
AGGRAVATION28 is offline
Old 08-25-2005, 08:59 PM
Default Re: Windshield glass removal
Trick is right. The rubber is spread to squeeze the glass to the frame. If it is not pliable or reusable, I purchased it new for $2 /ft from Ocean Dynamics in Fl. Put it in by soaping everything well and use a Popsicle stick to spread the bottom strip into the frame behind the glass. I found an old CD works well to slide under the strip and roll like a pizza wheel along the same plane of the glass(+5 degrees or more) to get the rubber to seal correctly. G$
Gmoney52 is offline
Prater
04-04-2015 07:49 AM
963b
4
02-12-2007 09:19 PM
GLH
0
06-30-2003 08:46 AM
p4-33
Fountain
3
01-28-2003 06:57 AM
p4-33
General Racing Discussion
2
01-22-2003 11:43 PM
Quick Reply: Windshield glass removal
