bottom paint
bottom paint
Any good way to remove bottom paint,I want to redo the boat this year and want it to look good,the existing is all chipping off,looks like it was sanded before they painted it.
Re: bottom paint
If the paint was put on right the gel coat was roughed up and the bottom paint was put on. I got an estimate from a glass shop to strip it and re-gel coat it for about $2,000 they also recommended applying VC-17 bottoming paint about $1,200, still a bottom paint but better looking and can re-coat when needed. It is on 26' foot hull.
Re: bottom paint
Re: bottom paint
Re: bottom paint
I used Petit Vivid bottom paint on my Stinger. Bright white multi-season paint. Looking at the boat you can't tell it's painted. Paint comes in several different colors and they can be blended to exactly match what you want. Great product. Check them out. Picture is of the boat with bottom paint applied.
Re: bottom paint
There was a 60 foot Sunseeker here this summer that had the Vivid white bottom paint on it--you couldn't tell it was painted. The owner complained about stains showing on the white but that would happen without the paint.
Mine has black bottom paint and I talked to Petit about coverage over the black with VIvid--they said whiate and yellow would cover the black without any issues if surface prep was done properly. THey've got great info on website.
The paint guy at the marina suggest I think about the problem the forklift woudl cause with anything but black bottom paint so I put the project on hold till I can get the boat an my own lift but as soon as I can get to that point I'm going with Vivid.
Re: bottom paint
I would like to try and match the color of the boat,looks horrible right now,I got the boat in may and put it in for the summer,I will redo it this winter,I am storing it in my works warehouse so I have heat!!
Re: bottom paint
i painted my first boat and i couldnt stand looking at it on a trailer. i will not paint this boat. i used it all summer this year and i leave my boat in the water. i pulled it every two and sometimes three weeks to clean the bottom and your right it does get old.the problem is not the bottom of the boat, its the outdrive and the tabs that get the worst of it. this year i will just store it and drop it when i want. but i will spend alot of over nights on it.
Re: bottom paint
I got my bottom paint off with oven cleaner, I srayed it on and let it sit for an hour and then blew it off with a pressure washer. I then painted the bottom with PPG deltron. ( my son did the paint, he didnt trust the old fart). Brian
Re: bottom paint
