removing swirl marks ?
AKA NoMoBoatin
Am i doing something wrong with my portor cable buffer.I'm using wax frenzy or meg. and i keep getting swirl marks on the boat.To fast of speed,to slow,or the wrong pad which s the black pad.Can someone school me on buffing and waxing ?
I just bought the pink Zainos Bros. wax for clear coats.... Havent used it yet but it came highly recommended by Offshoredrillin. I have used the blue Zainos on my cars and boats and it worked AMAZING!!! You might have the wrong pad... sounds like you need a finishing pad for the swirl marks.
PM Offshoredrillin....or GlassDave... they are the experts.
AKA NoMoBoatin
AKA NoMoBoatin
Originally Posted by US1 Fountain
I used Mequires 'Swirl Remover' as the final step when I buffed my boat out.
I have used the black foam pad with excellent results but as always, make sur the pad is CLEAN and fairly new, inside w/o sun or dust moving around ,paint or clear is cured throughout (hopefully not Imron or AwlGrip) min 3000rpm, but don't overheat. I use a spray bottle w/ distilled water (tap water has mineral contaminants that will CUT) to keep surface cool when appropriate. The others suggest polishes that I haven't used...yet. G$
AKA NoMoBoatin
